Old May 22, 2010 | 05:42 PM
JimmyJames's Avatar
JimmyJames
Default Re: Help ! Car will not start
This happened to me on my N/A about 18 months ago. About two weeks before totally shutdown, the alarm went off for no reason. I disconnected the battery and all was fine, or so I thought. Having owned a repair shop, I should have known better, but I am not sure that a tech would have been able to find the problem because for the next two or three weeks all was fine. I did have reservations when I started my car, but with time that passed.
I went into the store loaded up with groceries, and when I TRIED to start the car---nothing. Called a tow truck and got on here. Found out about the SCIRM (?) module in the trunk. Also found out about the fact that you have only 30 attempts before the computer TOTAL cuts out. I told the dealer what I had found, even showed them my ASE certs (Master Tech) because when I owned my shop. I had many customers that did not KNOW about modern cars, but boy, they thought that they did. They told me it was the key. I said no way---they said yes. I said no. I got the service manager involved and he sided with his tech. I said "put your money where your mouth is!!! I will pay your $428.00, but that is all I will pay---you have miss diagnosed the car." He took the bet. Two days later, I called and it was NOT the key. They said it was the SCIRM. I went down and TOLD them about the 30 times with the computer. They did not listen and cooked it. I ended up getting a NEW computer, SCIRM, and key. I signed papers saying the computer was bad under the emissions 8/80 warranty, but I only paid the $428.00.
So do your research on here and the MB forum---both helped me. My problem was more common with leaking with roadsters, but I had it with a coupe. GOOD NEWS is that it was fixed! Good luck and do not let them run up a bill. If they say 'X" will fix it----hold them to it. My told bill would have been $1600 so said the service writer.
Start with the basics FIRST---make sure that you have a good battery and connections. Both in the car and the key. Jimmy
Edit---I reread and saw both keys were tried. A three year old battery should be fine, but start there. Hook up another car with known good bat and alt. If still nothing, tow it to a dealer, so that you can show with the tow receipt that the problem happened BEFORE the warranty was out.
Edit#2---The reason that I KNEW it was not that key was I would disconnect that battery and the key would turn over the motor 3 times and then nothing. Tried again, disconnected the battery for 20-30 seconds, and the same thing---3 times and then nothing. That's how I knew it was not the key. How did my key KNOW that I disconnected the battery? It could not! It had to be in the car---It was. Try the above. Disconnect the battery and see if you get any respond.
