Re: need help with A/C problem.. compressor not engaging
Not sure on the Crossfire but many cars will not cycle the compressor unless there is enough freon pressure. On my son's Mitsu I simply found the wire going to the solenoid that runs the clutch, disconnected it from the harness, spliced in 12 volts and added freon. Reconnected the wire to the harness and everything works great!
