Old May 22, 2010 | 11:19 PM
onehundred80
Default Re: need help with A/C problem.. compressor not engaging
Originally Posted by HyprLtH20
need some help guys.. my car blows air but its not cool at all. I think i ran out of freon and the car tripped the compressor off for some reason. This all happened over night. the a/c pulley is turning but the clutch is not engaging the compressor. I have heard that in some cars you can follow the electrical line out of the back of the compressor until you find a clip and trip the switch to turn the compressor back on.. does such a thing exist in our cars? if so where is it?
I tried refilling the freon but since the compressor is not running it would not take in any..
Also, i can not run my a/c at full blast. when i turn it up past about the "3" setting it just stays at the same speed..
So any help is much appreciated I am really trying not to take it into the shop to have it repaired..
If the refrigerant leaked out overnight then it would be a waste of time and money to put more in. That's like putting more air in a flat tire before you fix the puncture.
Chances are it did not leak and you have another problem, disconnected wire at A/C clutch, bad clutch, fuse etc? Too much refrigerant is not good either.
Look at the workshop manual for clues.
There are threads here that deal with the fan control.
