Re: How to pull the pump without losing an ounce.
Well let me up the ante and raise you one photo.
Ill do the write up in a bit but you showed you hand and I wanted to show that Iam not bluffing.
The big issue that had me looking for an hour or so is where to locate everything to get the best servicability of the regulator. Ill be taking it apart a few times before I settle on the correct size dump orfice, SOOOOOOOOOOOOO I wanted to not have to fight the location while doing testing.
Also wanted to see the gauge and get to the adjustment, which I started at 65#.
This is on the rear of the vapor collection tank. Before some know not hypocephalic gets going, the wire ties are to hold it while the sealent hardens, and yess it is plenty solid with 3 square inches of surface area. Epoxy pops off and delaminates too easisly on glass filled plastic surfaces.
DONT KNOW IT THAT IS RIGHT CAUSE ITS RAINING BUCKETS............*#@%**&+/
Woody
Mounting of my WALBRO style pump/filter/regulator /gauge
Testing of previous fuel mod, traction limited
