Old May 24, 2010 | 02:59 PM
  #60 (permalink)
bmorgan's Avatar
bmorgan
Default Re: Well, Finally Got Off the Crapper w/ my wheels
Originally Posted by ///SilverSaphRT6
Ok thanks!! These just pop in the hub and stay right. Lot of choices to pick from. Do you happen to know the diameter I need?
Yep, just pop them in. The center diameter is 75mm. All mercedes wheels have the same diameter opening, so any of these should fit. Having said that, the only ones that seem to need a little tweaking to work seem to be the AMG ones in this pic. For some reason, they are too loose, but you can use a lighter to heat up the tabs and bend them out slightly and it will snug right up.
