Thread: new battery
Old May 26, 2010 | 11:20 PM
onehundred80
Default Re: new battery
Originally Posted by midlife chrysler
I also used the Interstate MTP-91 (and needed the spacer) but unfortuately it's closer to $200 here...
Better choice in Canada is this battery.
MotoMaster Eliminator #10-4800-8 (Canadian Tire, Canada)
(Looks similar to the MTP-91 above)
Identical to OEM battery, single strap handle, black case, identical vents, keep your original vent and the plug that goes into the hole the other end and fit to the new battery, no spacer required. 690 CCA, reserve capacity is 85 minutes, 3 year replacement, 9 year total limited warranty with 3 year roadside assist. YIKES! Can.$120 less $10 for return of old battery.
