Old May 26, 2010 | 11:28 PM
onehundred80
Default Re: removing the radio trim
Originally Posted by stlouisramsfan
adding the nav antenna, used the search function to no avail,
how do i remove the trim around the temp control switches/radio?
thanks
chris
You pry it off very carefully, use a trim stick. Do not use a screwdriver if you value the finish.
