Originally Posted by rcompart
Actually the transmission goes into limp mode because the sum/2 of the rear wheel speed sensors is not within the defined range when compared against the transmission output shaft speed sensor. It has nothing to do with the front and rear tires spinning at different speeds as was proven by Jim when he put on the smaller diameter rear tires.
So the taller rear tires will compensate for the 327 gear ratio?
