Old May 31, 2010 | 05:09 PM
muskrat's Avatar
muskrat
Default Re: Steering Vibration
Originally Posted by Bazzer
Does the vibration come through the brake pedal when braking? Warped brake disc.
No just through the steering
Have you checked to make sure you don't have a stone lodged in the tyre tread?
Checked tonight while checking for loose bits
Is the wheel rim square with the hub, i.e. no debris preventing the wheel to mate with the hub square?
Couldn't detect any run out by eye
Have you locked the front wheels recently under heavy braking and therefore flat spotted the tyre? Unlikely with ABS but still possible.
No
Failing all of the above, try another tyre fitting centre.
I watched the tyre place do the work both times and have used them for years
