Old May 31, 2010 | 09:41 PM
firemen's Avatar
firemen
Default Re: Fuel pump question
You can hear the fuel pump easier when the car door is open and you turn the key.
From the shop Manual;
The pressure regulator is a mechanical device that is calibrated to maintain fuel system operating pressure of between 3.7 - 4.2 bar (54 - 61 psi) at the fuel injectors. Fuel is supplied to the fuel filter/fuel pressure regulator by the electric fuel pump directly.
The fuel pump assembly contains a check valve to maintain some fuel pressure in the system when the engine is not operating.
If fuel pressure at the pressure regulator exceeds a set amount, an internal diaphragm closes and excess fuel pressure is routed back into the tank through the pressure regulator. The diaphragm pressure regulator (2) regulates the fuel pressure by means of the return flow (10) quantity to the fuel tank. If the pressure rises above the set pressure, the diaphragm (6) is pressed further against the compression spring (4). The valve (7) attached to the diaphragm opens the passage for the return flow further. If the pressure drops below the set pressure, the valve is closed again by the compression spring (4).
Thanks for the info. dude. All I need to do is put keys in the ignition and turn it so my console comes on with all the warning lights.
