Re: Radio Controls Lock Up
I had the same problem. It was very annoying. It worked some days and the next day it would freeze up and wouldn't do anything. I just replaced it with a new Blaupunkt MP48. It's a plug and play with no wiring needed. It sells for less than a hundred dollars and sounds great. I had to cut the phone mute line of the harness. It has all types of tone adjustments and a color adjustable display. You mix the RGB color to fit your own taste.
EOLJR
