Originally Posted by 32krazy!
i just helped jhm2k do this mod on his limited. he went #1 pad in the rear and #4 in the front. we will be changing the fronts to #2 pads for another 8 mm drop and even the car out. unfortunatly theres no shortcut for this mod!!!! you have to do the complete install and look at the car. then redo it again if it isnt the height you want. its very time consuming but rewarding.
the use of a spring compressor on the front could save you hours of work but the cost isnt cheap!
his car in stock form had #3 pads on the front and #1 on the rear
How much did you end up cutting off of the springs?
