Re: Karmann badge
also if the tires have been just replaced, they may have the wrong wheel for the tpm sensor pic-up, and may just need recalibrating to the car, or if there was a complete wheel swap, the sensors may not be matched up to recievers. make sure you have all the same syle valve assemblies and retaing nuts on your wheels, you should see a nut type retainter holding the valve together, not a regular stem valve, if all looks good I would say bad tpm sensor for wheel.
