Old Jun 6, 2010 | 08:32 PM
mrphotoman's Avatar
mrphotoman
Default Re: How to make your own low profile car ramps
Glenn's ramps.
Glenn's setup for getting his car up on the ramps.
Shel Myers from British Columbia made a few modifications to better suit his particular use. The ramps have pot lights installed (three on one ramp, two on the other), which allow each lamp to pivot and swivel in order to place light where it is needed. Each ramp has a switch to control each set of lights. The drivers side ramp has a built-in extension cord and power outlet so power tools can be used while working under the vehicle. Shel also made the actual 'ramp' portions with vertical oriented 2 x 6 in order to allow a vehicle to drive on without the need for additional supports. Shel also decided to make his ramps a full 12" wide using 2 x 6 lumber to do it since it was far cheaper and allows for easier rebuilding if one section fails or is otherwise rendered unusable. Shel also left two openings between studs unsheeted on the inside of each ramp to allow for tool and parts storage which proves to be very handy. View the pictures below:
