Re: Common Problem
You never know. I've got 72K on the original pump and it works fine. First see if your heat exchanger is plugged full of sand and junk and not cooling. You can remove the two plastic lower grills by using a screwdriver and releasing the plastic clips on each end. I used compressed air but a power wash would work also.
