Re: Moisture behind headlight cover
There is a TSB out on the problem. The dealer won't replace the headlight assembly, however, will install a kit that alleviates the problem. It seems that there vents that get plugged up. It appears to happen more on the drivers side assembly. There is no charge for the kit.
