Old Jun 8, 2010 | 12:46 PM
samcruse66's Avatar
samcruse66
Default Re: Crossfire: Supercharger - oil leaks.
Oil leaks in cars are a very common problem. Irregular maintenance and repair are the prominent reasons behind it. Oil leakage due to loosening of bolts and nuts can be fixed by tightening the bolts. Leakage due to loosening of the oil pan gasket is one of an example in this context. The most common area where oil leaks are found is the valve cover gasket.
The below given steps would tell you how to repair oil leaks in car, when the valve cover gasket is damaged. The first and the most important step is to detach all the breather hoses and spark plugs off the valve cover. Now, just tease the bolts of the valve cover and then remove out the valve cover. Now place on the new gasket
