Old Jun 12, 2010 | 01:56 PM
Bladecutter's Avatar
Bladecutter
Default Re: clutch is jacked up
Originally Posted by Kookev
Where is the slave cylander on an 04 .... clutch is jacked up. Drove home from work fine....got in it about an hour later and the clutch was tighter. And the car wont start unless in neutral with the clutch mashed to the floor. Or is that not even the slave cylander...any help would be appreciated !
Bat's car just did the same thing 3 weeks ago.
Fingers on the pressure plate aren't coming back to their rest position fully, causing issues similar to yours.
Car only has 9k miles on it, and is an '08.
Warranty is replacing the flywheel, friction plate, and pressure plate due to glazing, hot spots, and the weak fingers.
BC.
