Old Jun 18, 2010 | 03:42 PM
Infinite's Avatar
Infinite
Default Re: Secondary Air Pump CEL
You can trick the ecu into thinking the pump is still there by using a load resistor, just measure the load across the contacts on the pump.
I've disabled my air pump, as it causes the a/f ratio to be erroneously lean. I still have the CEL but it doesnt bother me. Right now Im working on the load resistor fix to see how it works out.
There should be a way through the PCM to disable the air pump.
