Old Jun 18, 2010 | 04:35 PM
spikehound's Avatar
spikehound
Default Re: Rain Leak / Passenger Side
Originally Posted by blackcrossfire07
Make sure the water is not coming in from around the window first before you start pulling crap off your car. I had a small leak near the black triangle. Turns out the window just needed a simple adjustment (a common problem on our cars). After a couple adjustments at the dealer it stopped leaking. The passengar side window was not making good contact with the rubber strip.
It's definitely not coming from the window because it is leaking from under the dash on the passenger side. Thanks for that bit of info though.
