Old Jun 18, 2010 | 07:40 PM
NeedsWings's Avatar
NeedsWings
Default Re: Stops Like Hell Packages
we can also have calipers coated with some sort of caliper thermal coating. i'll have to get more info on them but they do them all the time for high end racing teams. it basically keeps the fluid cooler. the caliper needs to be disassembled for it to be applied.
we can get brembo bbk's but since i beleive the stoptech's to be superior i havent listed them up, there are in the 4k range for the fronts and another 3-3500 for the rears. i cant imagine anyone ever purchasing them and figured id be wasting my time listing them but is there ny interest in digging up a real quote on them?
for the limited and base crossfires
front pad options..
Axxis Ultimate109.07400C-TEK Standard Metallic102.07400Centric Premium Brake Pads w/Shims300.07400Centric Premium Ceramic Pads w/Shims301.07400OE Formula Brake Pads100.07400Posi-Quiet Ceramic w/Shims105.07400Posi-Quiet Extended Wear w/Shims106.07400StopTech Street Performance Brake Pads309.07400
rear pads...
Axxis Ultimate109.07790C-TEK Standard Metallic102.07790Centric Premium Ceramic Pads w/Shims301.07790OE Formula Brake Pads100.07790Posi-Quiet Ceramic w/Shims105.07790Posi-Quiet Extended Wear w/Shims106.07790
front rotors...
C-TEK Standard Rotor121.35058Power Alloy Discs125.35058Power Slot Slotted Brake Rotor126.35058SLPower Slot Slotted Brake Rotor126.35058SRPower Slot Slotted Cryo Treated Brk Rtr126.35058CSLPower Slot Slotted Cryo Treated Brk Rtr126.35058CSRPremium Cryo Treated Rotors120.35058CRYSportStop Drilled & Slotted Brake Rotor127.35058LSportStop Drilled & Slotted Brake Rotor127.35058R
rear rotors...
C-TEK Standard Rotor121.35012Power Alloy Discs125.35012Power Slot Slotted Brake Rotor126.35012SLPower Slot Slotted Brake Rotor126.35012SRPower Slot Slotted Cryo Treated Brk Rtr126.35012CSLPower Slot Slotted Cryo Treated Brk Rtr126.35012CSRPremium Cryo Treated Rotors120.35012CRYSportStop Drilled & Slotted Brake Rotor127.35012LSportStop Drilled & Slotted Brake Rotor127.35012RSportStop Drilled Brake Rotor128.35012LSportStop Drilled Brake Rotor128.35012R
