Old Apr 20, 2005 | 06:17 PM
Crossfire-tech's Avatar
Crossfire-tech
Default Re: First Oil Change
[B]
Use Mobil One 0w-40 and watch out chrysler will be watching out for proper maintance
records
[U[/B] Maintenance Schedule A
Change Oil and Filter change
(Using Mobil 1 0-40, Filter & washer fluid) Parts 83.50
Maintenance Labor 56.00 .8 hrs
• Lube Hinges, Hood Latch, secondary hood Latch Total 139.50 + tax
• Reset the FSS display
Inspection
• Check Horn, Hazard Flashers, Turn Signal, Indicators Lamps, Head Lamps, Exterior Lighting, Wiper system
• Inspect Brakes, Tires, Wheels for damage and Inflate tires
Check the Following Fluids
• Cooling System (check corrosion inhibitor/antifreeze)
• Hydraulic Brake System
• Power steering System
• Washer System
Maintenance Schedule B
(Using Mobil 1 0-40, Filter & washer fluid) Parts 147.50
Maintenance Labor 126.00 1.8 hrs
• Rotate tires Total 273.50 + tax
• Replace air filter
Inspection
• Check Seat Belts
• Washer System
Cooling System Service Parts $36.00 Labor 1.3 $91.00
Replace Air Filters Parts $64.00 Labor .5 $35.00
Service transmission Parts $71.00 Labor 1.3 $91.00
$10.00
Service Rear Diff. Parts $50.00 Labor 1.3 $91.00
Brake Job (front) Parts $70.00 Labor 2.0 $140.00
Brake Job (rear) Parts $70.00 Labor 2.0 $140.00
Rotate Tires (and Retrain Sensors) Parts Labor 1.0 $70.00
W/ Balance 1.5 $105.00
Alignment Parts Labor 2.5 $175.00
Balance Tires Parts Labor 1.0 $91.00
Power Steering flush Parts $37.00 Labor 1.0 $91.00
Brake Flush Parts $16.00 Labor 2.0 $140.00
Tune Up Parts $114.00 Labor 3.0 $210.00
