Originally Posted by +fireamx
I'm not into drifting at all, unless it's on a very large (obstruction free) snow/ice covered parking lot. But since I don't drive the XF in the winter, I'm out of luck. And what I do drive in the winter has front wheel drive, so again, I'm out of luck.
But couldn't you compensate for the "NA" Crossfire's pitifully weak power by simply installing skinnier tires?
To a point, yes. THe problem is on some of our layouts, you need lots of power because you'll need to carry 3rd gear around a large up/downhill sweeper in order to have enough momentum to finish the course (which drops to 1st by the last clipping point)
I've had all the way down to 235/35/19s on the rear, it helped a bit but not enough. I'm going to put 215/25/19s on and see what happens. If it still cant carry a slide I'll put 18's on the back
pulling the traction control fuse also disables the yaw sensor, and abs, and the esp,bas
