Old Jun 23, 2010 | 02:11 PM
typhoon55's Avatar
typhoon55
Default Re: Low coolant warning light
Originally Posted by typhoon55
Also have the same exact symptoms ie: coolant light on - fluid reservor is full
ac is intermittant cold / warm
seems light comes on when ac is engaged
One post did say light will come on when fan is supposed to kick in but does not.
I did have the fan recall done a while ago
I believe fan and module were replaced under recall.
fan module part number & cost ?
will jump out the fan - after reading archives, it seems it is evenly split between fan and module
Jumped out fan and it engaged
another xfire with a bad control module or not?
I swapped out module with another used one and fan worked and coolant light gone but next day symptoms appeared again
Could be used module bad or something else. Fan does work when jumped out still
