Old Jun 23, 2010 | 05:27 PM
  #203 (permalink)
Infinite's Avatar
Infinite
Default Re: Rotrex Guy
Progress is looking good so far. The one thing I've been looking at with the air-water setup im debating running is bleeding the system, I plan on using the same core as you and with it placed so high, all of the air in the system is gonna accumulate in the intercooler.
I was thinking about having a bung welded to the top of the fluid passages to have a continuously bleeding coolant system for the intercooler, but I couldnt find a suitable place high enough for the surge tank.
Maybe you can look at it from a different POV since you have the intercooler rather solidly mounted.
Also, how are you liking the FIC? I'm about to pick one up to start building base maps and get everything running smoothly (similar to you) before I start installing turbo components.
And you wouldnt have those spare injectors still would you? Dont forget you'll need a new fuel pump as well
