Re: Convertible top won't go down
Maybe someone can help me with my convertible top problem. When I use the switch to open the top the windows open, the beeping will continue till you release the switch. The top does not open. I've checked the switch in the truck and held it manually with the divider down and the top still will not open. Just went out and tried it again, pump doesn't run, left key on and window down. I decided to try the open switch again and it opened. Closed the top, shut the vehicle off and tried to open the top again. No go, still same thing. won't open. Let it set for a few min. and it opened. Just confuses me. Of course that doesn't take much!!!
