Old Jun 28, 2010 | 04:58 PM
onehundred80
Default Re: radiator fan / control module
Originally Posted by typhoon55
After reading numerous posts on engine coolant light issue, I discovered the fan was DOA.
The fan or the module seem to be at fault - fuse is ok by battery
I jumped out the fan to 12v and it checked out fine
found a used control module and installed yesterday.
That seemed to fix the problem as fan worked and coolant light went out today coolant light returned and no fan.
How can i test the control module before I go get another one?
Is there a cross reference to our part #05102818aa
Go to section 7.1 of the Crossfire service manual and all is revealed.
You will need a good multimeter and the ability to use it which is not hard.
http://www.majormotorshotrods.com/_d...ice_Manual.pdf
If you haven't already done so, download and save the whole manual to your computer.
