Re: What Do You Think Of This Oil?
generally, thinner oil is used because clearances are a lot smaller. Thicker oil will run off where thinner oil will lif an separate forming a "skin". Good example would be the clearances between rod bearings and the crank. The journals for the cams as well. Once you have metal on metal spinning @ 1000's of rpms, the damage is done...
