Old Jul 2, 2010 | 06:29 AM
Infinite's Avatar
Infinite
Default Re: Differential Oil Change!
soak the plugs with pb blaster or some sort of penetrating oil before you attempt to remove them. They corrode and have been known to strip before they come out. If that doesnt work heat the case around the plug with a propane torch, that will pretty much break up any corrosion
