Re: Best Tire size ??? 20X8.5
Dwight is right. (
)! I think it looks like a 19/20 staggered set. That's what I run. I added spacers to keep OEM offsets (35 Front/22 Rear), then needed 5 mm more to clear that darned
ball joint nut in front.
Be aware that the tire width (225 or 235) along with the taller profile (only 1/4") might get you too close to the upper ball joint nut. Spacers needed then Not expensive ($50-$75 US/pair).
with oem offsets can I definitely afford spacers even in a drop? I look at other forums and it says that the lower the offset the better to a certain point.
