Old Jul 3, 2010 | 05:57 PM
LEGEND's Avatar
LEGEND
Default Re: Help Please Anyone!!!
Originally Posted by MikeR
Legend, I just looked at mine and the wiring is the same as your pic..... since there are two red/green lines side by side, I cant tell you if you have them correct.... the schematics would tell you if they are common...
edit: you can find the schematic for the RCM in the service manual on pages 8W-10-21 & 22. The connector you are showing is E. Looking at that, the technically go to specific points, but they both come from the same relay in the RCM so it shouldnt matter. Being ****, I would use a meter and make sure they match the schematic.
Thanks MikeR for your quick response,when I took a closer look to the lines I noticed a indentation made by the plug cap on the line I put in the #6 cavity, also check on the service manual the gauge of the lines,Yes they where wrong positioned.
The service manual is full of errors,it says that the D connector is black and in my car is gray like the E connector;Also states that the line in the #6 cavity in the E connector is BK/DG,there is only one BK/DG
going to that connector and it goes to # 4 cavity.
Reference--------- 8W - 80 - 57 2004 Service Manual Volume 1 of 2 Crossfire.
Thanks again MikeR, Im very greatfull for your help.
