Re: First Oil Change
The manual says to change the oil at 7000 miles or in Canada about 11000 km. That is if i figured it out correctly.
I don't know what the numbers that you were getting means. You will only get two wrenches if the FSS system thinks you need the more frequent service. I will look in the repair manual to see if I can find out what the number means. Will let you know.
