Re: First Oil Change
DESCRIPTION - MAINTENANCE SCHEDULES
Again right out of the service man.
SCOPE OF WORK FOR “A” SCHEDULE MAINTENANCE SERVICE
Oil Change
Change the oil and replace the oil filter
Maintenance
Lubricate the hood hinges, hood latch, and secondary hood latch
Reset the FSS Display
Function Check
Horn, hazard warning flashers, turn signals, and indicator lamps
Headlamps and exterior lighting
Windshield wipers and washer system
Inspection
Check front and rear brake pads for lining thickness
Check tires for damage and general condition
Check tire inflation pressures and correct if necessary
Fluid Levels
Check fluid levels for the following systems and correct if necessary. Should there be a loss of fluid that cannot be explained by regular use, trace and eliminate the cause.
Engine cooling system (check corrosion inhibitor/antifreeze)
Hydraulic brake system
Power steering system
Windshield washer system
SCOPE OF WORK FOR “B” SCHEDULE MAINTENANCE SERVICE
Oil Change
Change oil and replace filter
Maintenance
Rotate tires
Replace dust filter
Lubricate hood hinges, latch, and secondary latch
Reset FSS Display
Function Check
Check seat belts for damage and proper function
Test hydraulic brakes and check parking brake function
Inspection
Check condition of front and rear brake discs
Check major underbody components for leakage or damage (if there are signs of leakage, determine cause and repair)
Check condition of front axle ball joints and rubber boots
Check condition of steering components and rubber boots
Check underhood components for leakage or damage (if there are signs of leakage determine cause and repair)
Check condition of accessory drive belt
Check headlamp aiming, adjust if necessary
Check windshield wiper blades, replace if necessary
Fluid Levels
