Old Jul 4, 2010 | 08:08 PM
MikeR's Avatar
MikeR
Default Re: The wing is the thing see ya in carlisle
Great job Woody..... I got a little circuit that wires into the high break light so they flash three times then go solid when I hit the breaks......
I also pulled my wing yesterday, but for a different reason... I noticed water drips when I lifted the tail gate after the rain(I still have the lining out of my trunk space)...
I found that I had a tiny bit of rust on the wing bolts and just wire brushed them... the panel that the wing sits on was my problem.... there is a gasket that goes around the underside and it had slipped inplaces and was letting a little bit of water in.... I fixed it by adding the same black gasket RTV I used on the valve covers all the way around the factory gasket and around the bolt holes for the wing (to re-inforce the O-rings)....then tightened everything back down....
