Kolevski, So far the ride is fine... I have had the springs in for about 4 weeks... I may take it for a drive to the coast today and see how it handles going through the mountains.....
Les, I intentionally try NOT to hit pot holes...the road to the coast has some areas that are a little rough and some sunken grade areas that drop or rise from repairs....
I forgot to mention that I finally FIXED my rattle in the back... I have been living with it as all the usual fixes... havent .....
I had read on here that someone mentioned the wing being loose might be one cause and since I had my wing and base off Saturday to re-seal I was hoping that might be part of it..... not!
Then while I was installing the adjustable camber arms I needed to take the rotors and calipers off..... what's this.... left rear caliper top bolt is very loose..bottom is seated but not tight.....right side was fine. I didnt use any blue loctite on the bolts when I installed the new rotors and Goodridge lines.
needless to say I did use loctite this time and tightened them.... the normally rattling ride from my house to the freeway is now nice and quiet......
