Old Jul 6, 2010 | 06:35 PM
tighed1's Avatar
tighed1
Default Re: Transmision Probs, not "limp mode"
FYI the procedure to check the trans fluid level is krazy.
I just added another quart of fluid and all has been fine since then.
The trans fill tube is covered by a "one time use" locking cap. You CAN reuse it. Just keep track of the tab that you have to break off in order to remove the cap. Use that tab to relock the cap in place.
NOTE: Make sure you use the correct type of trans fluid!
If you put too much fluid in it will just get burped out of the trans through a vent (according to Professor Woody).
