Old Jul 8, 2010 | 11:38 AM
Coyote's Avatar
Coyote
Default Re: Strange Transmission behavior
Originally Posted by robby363
If it gets worse you might want to have the fluid level checked. I've had mine do the same in second gear and have had to stop and restart the car to get it back to normal. I have the leaky connector plug I need to fix and when the fluid gets low it gets stuck in second and will also cause it to go into neutral when I accelerate hard.
Thanks for the thought on the tranny fluid. I had the TSB for the leak fixed several years ago, but it could be that the tranny is a little short of fluid. Think I'll have the Service Center check that on Saturday.
Coyote
