Old Jul 10, 2010 | 10:49 AM
Jeep2Xfire's Avatar
Jeep2Xfire
Default Re: Brake Pad Replacement - DIY?
Originally Posted by 32krazy!
i have done numerous crossfire and slk brake jobs. this is a 2 on a scale of 10 if you have a few handy items
1. PATIENTCE!!!!! the torx bolts are not visible and can be a pain . take your time
2. motive ind. power bleeder.(50$ from jegs) this handy tool will ensure all the air in the system is gone and allows you to see the fluid moving thru the system
3. 1/2 gal jug and clear line. this allows the fluid to stay off the floor and you will know when the clean fluid is passing thru
4. this is a great time to replace the oem rubber lines with braided lines. cheap to do and looks and works great
let me know if you have any questions during the install
And if you're gonna do the braided lines, be sue to soak the caliper in a tub of alcohol to get the brake dust off & out. Paint those calipers while you're at it...
