Thread: rad cooling fan
Old Jul 10, 2010 | 10:20 PM
James1549
Default Re: rad cooling fan
I understand what you are getting at. But for the fan to run without the engine running, would only reduce the heat to a minimum. Without the water circulating through the engine, I don't think it would do much once the radiator is cooled down. Now if you could install an electirc water pump to run at the same time you may have something.
James
