Old Jul 11, 2010 | 09:54 AM
32krazy!'s Avatar
32krazy!
Default Re: Do you hear the rear ???
Originally Posted by amx1397
woody, i sent mayham a pm for rudy and myself,, her is the just of it ,, " you have a good ring and pinion and rudy has the rest of the diff ,, with the two we could build one ,,,weld it weld the spiders on all sides weld the pin into the housing, this way it becomes a bulit proff rear week link being the ring and pinion the reasion for this is to make sure the wavetrac is worth the money and make sure we are not spending 1200 dollars and find out there is another week spot like axles or whatever, if you mayham gould get with rudy send him your R&P he would install everything weld everything and send it to me for testing. thanks jim"
jim i get the idea of what you are wanting to do but remember the weled internals will be a bear for everyday rides or those that want to autocross.
as far as weak links go as a racer you are well aware once you fix 1 weak link another will always show up. power always transfers to the weakest spot. wavetrac was not ever designed to strengthen the axles or the carrier bearings. it is the cure for the weak spider gears and internals and to evenly transfer power to both wheels. if the ring and pinion then fail it isnt because of the wavetrac or any welding work you have done. moving parts fail. moving parts under high hp and tremendous stresses fail faster. its part and parcel of racing
more than anybody i want a fix for this issue. i have big plans for my 32 but everything is on hold until the diff is fixed. everyone wants a lsd but balk at the price. racing costs $$ compare the cost of the diff to everything else you put in your car and its a decent and cost effective mod
