Re: Get your rear in gear
The computer is looking for a certain number of pulses from the wheel "tone" ring. The pickup is the wheel speed sensor and if a replacement ring were to be cut and installed to give the speed sensor its correct number of pulses; the computer would give no codes and the abs would be intact
Wouldn't the different amount of pulses coming from one wheel be interpereted as wheel slip and cause the PCM to apply T/C or ABS?
