from manual:
Set Condition: Calculated ratio not within allowable range for the engaged gear. No shifting operation. The
TCM constantly calculates the transmission ratio based on the N2 - N3 input speed signals and the calculated
output shaft speed (CAN message from the ABS). The TCM will detect if the transmission is slipping or an
invalid gear ratio is present.
You guys are right again!
