Thread: Best radio
Old Jul 12, 2010 | 12:49 PM
oppizzippo's Avatar
oppizzippo
Default Re: Best radio
Originally Posted by VIPER0076
...Is there a good radio that is plug and play and still uses our amps and sub woofer...
All radios that are single din size will work great. Just choose the one that best fits your needs. I suggest getting one that has 2v or more preamp outs and wire it with a harness that is designed for using the preamp outs. I hooked mine up using a harness that was designed for using the internal amp in the headunit and it caused distortion. I had to splice in some RCA cables on the speaker wires of the harness to use the preamp outs.
...or are we stuck not using the rear speakers at all?...
The factory amp just has 1 set of left and right inputs for all 6 speakers.
To summarize get the harness that is made for preamp out (local shop is a good place to start) and use any radio you want.
Cory
