Old Jul 13, 2010 | 05:30 PM
  #45 (permalink)
billvp's Avatar
billvp
Default Re: Engine flutter? Normal?
the click noise just after the throttle starts in those videos is the noise fo the s/c clutch engaging. we noticed the c3 pulley made a much more noticable engagement than the oem s/c pulley did. im not hearing an issue further up in the rpm band from there in the video though.
I also didn't hear it in the Crossfire clips. In the truck soundclip it was evident though. I'm also not hearing it in my car any more, so who knows ... maybe I'm just going deaf
Originally Posted by satellite
The reason I am leaning towards exhaust leak (at the headers/manifold) is that my truck just started leaking badly from the headers and it's a fairly similar noise....here is that noise...as you can tell MUCH more prominent....
What are the chances that BOTH of my cars get the same issue at the same time...
be careful...louder clip
99' Dakota R/T Exhaust Leak at driver's side header - Most likely gasket is just completely bad from header bolts working their way out....
