Re: ball joints require whole control arm?
If it's a lower ball joint you can replace just the ball joint. It lists for $52.60 If it's the upper you might need the control arm. On some control arms you can drill out the rivets and bolt in a new ball joint I not sure if it can be done on the upper control arm on the XFire though.
