air in brake fluid
Jul 14, 2010 | 07:47 PM
permalink
BrianBrave
<--- Huge Horsepower
Apr 2007
3,217
So Cal
- Forum Super Sponsor -
Re: air in brake fluid
Lots of valves and such with our braking system. I found that g
ravity bleeding works well on our cars.
With the SRT6 level on jack stands - I
used the clear tubing that came with my boost gauge (cut into four pieces) I slipped one end onto each caliper nipple and the other end into a small container to catch the fluid.
I had the brakes completely apart so there was no old fluid, but you could also use a turkey baster and suck most of the fluid out of the master cylinder to speed the process.
If you use a different color brake fluid it will help to see when the old fluid is completely flushed. I used ATE SuperBlue and a resevoir feeder to keep the master cylinder from emptying.
Then cracked all the calipers and watched until a steady bubble-free flow was going thru the tubes. Then closed each caliper.
Only regret I have was the Rotex Gold pads. Great when new and sure kept the dust away, but not a good performance pad. (and not supposed to be)
Hope this helps.
BrianBrave
View Public Profile
Send a private message to BrianBrave
Find all posts by BrianBrave
