Old Jul 15, 2010 | 01:56 PM
ZAHANMA's Avatar
ZAHANMA
Default Re: I did that! White dashboard light!
HellFire,
Go easy now. Even if you are in fact poking fun at yourself, you must also considered how what you write may be perceived by someone reading it. So much of what we mean is contained in the intonation of our voices, which we lose when we make a post, or send an e-mail. This is something that should be kept in mind. It also helps to use these ( ) to try and get some meaning across.
Cross-fired,
I would like to thank you for taking the initiative to take on such a project that does seem quite time and resource consuming. I believe I understand what you are stating for a general plot of how to accomplish this. Please let me know if I am understanding correctly:
A) Disassemble the dash (even though I don't know how, I'm sure I could find out by using the search function)
B) Remove the green film that is covering the luminated parts of the dash by 'rubbing' which I assume is quite vigorous and takes some sort of very fine sandpaper. I have not disassembled the dash and instrument cluster to date, but is it safe to assume that this will not come off in one piece by is more similar to removing paint?
C) Re-connect all of the electronics that were disconnected in the disassembly phase, and replace the bulbs behind the dash to whichever color you prefer.
D) Reassemble the dash
E) Repeat for other areas (HVAC controls, Window Switches, and Gear Selector, etc.)
Thank you again for planting the seed in our brains for a new modifications to make each of our crossfires more unique. Please do not let any confrontations in the past keep you from continuin to modify your car and especially please don't let it keep you from posting it here. We would all love to hear about it...with pictures. Thanks again.
