Re: BAS & ESP Light
Originally Posted by cojo2004
BAS ESP Light - 2004 Crossfire
My BAS ESP Light would come on after startup
only once the brake pedal was pushed.
I determined that the
Stop Light Switch (Standard Motor Products # SLS392, $16.00) was faulty. There was a melted pit burned in the switch plastic sliding surface area that caused the circuit to light only momentarily and only at the beginning of the pedal push. Replaced the switch, all good to go.
Maybe your sop light switch is incorrect adjustment, short circuit to ground or wiring/plug connection between pressure sensor and control module is faulty that's why your stop light switch was also faulty.
