Originally Posted by Infinite
theres no reason you should lose boost pressure from long piping... the column of air inside the pipe is pressurized the same.
if you had like, 20 ft... vertical i could see it, but not from 10-12ft of straight pipe. Thats why I said the guys at STS are mildly retarded.
We have guys that run some 15ft of intercooler piping on some setups and the only pressure drop is 1/10th of a psi across the intercooler.
might they be talking about the bends then?
