Old Jul 18, 2010 | 03:33 PM
32krazy!'s Avatar
32krazy!
Default Re: Need some help, could it be the inter cooler pump?
Originally Posted by HellFire
Anyone ever tried to I/C pump from a Porche Cayenne? I had one laying around, so I ised it instead of the others normally used. I could not find the flow for it anywhere, but I was pretty sure it was more than my broken one was pushing. LOL So far, it seems fine and no problems, but I have only had about 5k on it. Since the diameter was smaller, I had to wrap it to use the factory mount, but it does seem to do the job. I am enbarassed to share the wrap idea I used, but it was a last minute ghetto job with a shop rag. LOL I thinkl the pump was only 80 bucks new. I was going to use it for a sprayer set-up. A totally different project, but it was not necessary. I am glad I found a good use for it. LOL
would need to find some part # for the pump to research the flow rates. as long as it is ok for coolant use it should be fine.
remove the rag and use a 2$ bicycle tube cut to fit and wrap it around the pump to fit it in the oem rubber sleeve
